msd help please - Performance Forum
msd help please
Wednesday, October 08, 2008 11:40 AM
i need a pinout for a stock 95 2.2 ignition control module from someone who has done this or has a service manual,
thanks
jason
Re: msd help please
Wednesday, October 08, 2008 11:48 AM
what is this??
What are you trying to hook up? A dis 2? if so which model?
You should be able to find the proper connections easily with a test light/voltmeter.
Re: msd help please
Wednesday, October 08, 2008 7:44 PM
yes its a dis 2 with blaster coils model number 62112 dis-2 plus
thanks in advance
jason
Re: msd help please
Thursday, October 09, 2008 6:50 AM
Well, you need the coil interface modules, part number 8870 available here
Then all you need to do is simply determine which pin on your ICM is which (as described in the install manual) here
and the install manual for the interface modules here
monster mash those 2 things together, and you will have an easy trouble free installation.
Also, if you run into problems, MSD's techline is actually very helpful and knowledgable.
Re: msd help please
Thursday, October 09, 2008 9:22 PM
well all the install manuals were wrong and i havd the msd tech draw one up so here it is for all the 95 2.2's
Re: msd help please
Friday, October 10, 2008 5:29 AM
all he did is label the colors for the interconnects to the MSD box, in other words, he filled in what you needed to find with the voltmeter.
But, as long as you got it hooked up......
