I'm redoing the motor in my 98 cavalier that has Ld9 in it.. But I'm unsure on what compression ratio would be better. It's going to be turbo charged,valve job ,cams crank work and other things so I'm not sure what would be better Wiesco Forged Pistons 9:1CR .020 Overbore or Wiseco Forged Pistons 10:1CR .020 Overbore?? Or if anyone else had something different in mind. Thanks
ultimately it depends on the boost level you would like to run.
me personally, im going to be running those 10:1's and about 10-12 psi.
Needing 2.3 oil pump stuff? PM me...
Well just for driving it around town and stuff i plan on running about 5-6 psi. But when at the strip about 13-15psi. I also want the motor to last a long time.. I'm sending my oil pump to jbodyperformance to (neutralize them) as they say. And im sending my crank shaft to them also for there Lightening/Knife-Edge Service.  Cause there is no one around me that i trust to do kind of  work!! Thanks you
Please do some research on JBP.
I've email JBP person and  he said i just have to send him my crank and they will take care of it.. But the more i think about it and read some postings about the 2.3 oil pump swap i may do that.. Do u think its worth getting the crank done with the Knife-Edge??? Will it really improve it??
Talk to people that have had work done by them.  Personaly I would not send them my work.
ok i will start asking around. Thank u very much i don't like wasting money on @!#$ty work!!
Holy @!#$ thats is so F**ked up ,wow im am soo glad u showed me that. Thank you so very much im going to email those asses and tell them there not getting @!#$ from me!! Thanks again Man..!!!:-))))
Do u knw where i can get a after market radiator?? I emailed griffin but not response yet..
I had one made by  a local place, kinda pricy though.  I rather suspect that with a decent fan set up an aftermarket radiator wouldnt be required for a high power build.
98 Cav wrote:Well just for driving it around town and stuff i plan on running about 5-6 psi. But when at the strip about 13-15psi.
lol there's no reason to electronically or mechanically limit boost for daily driving, you can control the amount of boost you make by controlling your foot..
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Yeah but i don't need all that boost to pass a car and stuff..
so, are the jbp parts good?  like the lifters and rockers, etc...i would love to build my own engine, but some parts i just don't know where to get
I will not buy anything from JBP anymore after reading this
http://www.j-body.org/forums/read.php?f=22&i=47867&t=47867!! (mitdr774 )
sent me this site and like i said after read ing this,then u decide if u would buy anything from them!! I have been looking around and found a lot of good sites..
Turbotechracing.com
Rksport
quad4performance
carcustoms.net
Im buliding my own engine 2.4 and so far these are the best sites i have found!! Hope this help you
hmmm...well, between turbotech and importperformanceparts.net, i've found a lot, but some things i just can't find on there...thanks for the sites though.
lol, i should probably mention i have a 2000 ln2 engine, not the ldp
not really.... at all
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
[ion wrote: C2]98 Cav wrote:Well just for driving it around town and stuff i plan on running about 5-6 psi. But when at the strip about 13-15psi.
