Does a Ecotec fuel pump always stay on when running?
Or does it switch on and off as needed?
Thx
I would assume it stays running to hold a certain PSI in the fuel line. As soon as the pump kicks off the fuel pressure drops and you would feel the car start running weird almost instantly.
all fuel injection pumps stay running when the car is running
gm turns them on for 2 seconds at key on , then constant once you start it and its running
[quote=97cavie24ls(™)]all fuel injection pumps stay running when the car is running
that's not true
but yes the pump in jbodys run constantly
Darkstars wrote:[quote=97cavie24ls(™)]all fuel injection pumps stay running when the car is running
that's not true
ok mister VW with mechanical injection , lol
if the pump isnt running , or mechanically pumping , then the fuel pressure will die off and the motor will loose power , i dont know of any pulse pump systems
and hybrids are a different animal
All return less fuel systems are pulse width modulated.
