Just wondering if it would be possible to put a 2.4 crank and internals to our 2.2 eco's.
I know is a long shot but I havent found anything in searching.
had a blown ecotec swapped 2000 cavy, now just an 02 Grand Am, and a 74 BMW 2002...
damn I cant find the edit post button, I meant to say put a 2.4 eco crank into a 2.2 eco
Yes, but you are going to need to swap the rods and pistons too. Then you have to deal with our ECU not reading the LE5's relucter wheel. I.E. Run a standalone or see if the wheel is removable and having one with the proper amount of teeth made and hope that it works.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Or you can buy external reluctor wheels that bolt to the crank pulley. They also have some adjustment in them cause you can move the crank sensor around to advance or retard the timing as needed.
