I got the throttle cable off, but I can't figure out how to remove the cruise from the throttle body
Thanks,
I think if you posted in the right forum, you might actully get some some. This is the
Performance Forum, you are looking for the
Maintenance Forum
It would be the one I have highlighted in red for you. I hope this helps you next time you posts.
for ld9 just pull on it. pops rite off. use a flat blade if you need to... unsure bout other motors. id assume so because gm rarely changes stuff like tat.
I must confess... I feel like a monster!
on the eco there is a little clip that slides into the bottom of the throttle cable where it attaches to the throttle body. get a small screwdriver and dig it out the bottom and it should pop off
