what would be a good head swap on 01 ld9 with an m62 charger and bored 20 over 9:1 cr any info thanks
color me lost... but i do not quite understand what you are getting at...
if you want higher compression you could do a 2.3 head or an older 96-98 ld9 head.
I must confess... I feel like a monster!
why would you go 9:1 compression with supercharger? waiste of power there, to makeup for it you would have to go with the 086 head, but then running the supercharger , you may have to mod the manifold(not sure on that one), you should put compression back to stock or upgrade compression to help with the supercharger, if ou upgrade the pistons, go with 96-98 head, if you want to keep compression, get rid of charger and go turbo with 086 head
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
yea i know i had the pistons but. i was looking at a 086 head and i was wondering what i wood have to do to make it work
look it up man there are tons of posts about it, just have fun using the supercharger with the head
Match it to a 2.4 head gasket and you will need manifolds from a 2.3. thats the quick version lol...there is a good thread with pics if you search. with the 9-1 pistons you should end up with about 10.5-1 with the 086 head which would be fun with the m62.
with an m62 charger
9.0:1 would be safe....
I would not go above 10:1...... but thats just me.
Stock 00-02 is around 9.7 (yes please argue me on that.... so I can pull up SI and show you.)
Id stick with that. and the M62.
Chris
'02 Z-24 Supercharged
ok, im aruging
got pics of your current setup? I plan to run an MP62 with an 086 head soon.
Well if you want a brand new 086 head let me know...here are pics for better visual learning LOL
GMR has got nothing on this
Service Information
2002 Chevrolet Cavalier | Cavalier, Sunfire (VIN J) Service Manual | Engine | Engine Mechanical - 2.4L | Specifications | Document ID: 752549
Engine Mechanical Specifications
Application
Specification
Metric
English
General Data
Engine Type
Inline 4 Cylinder
Displacement
2.4 L
146 CID
Regular Production Option (RPO) Code LD9 VIN Code T
Bore
90 mm
3.54 in
Stroke
94 mm
3.70 in
Compression Ratio
9.7 to 1
Firing Order
1-3-4-2
Do Not Resurface if the Overall Measurement is Less Than
0.076 mm
0.003 in
Resurface the Head if the Overall Measurement is More Than
0.076-0.25 mm
0.003-0.010 in
Lubricating System
Oil Pressure @ 3,000 RPM
207 kPa
30 psi min
Oil Pressure @ 900 RPM
69 kPa
10 psi min
anymore?
Chris
