looking for somebody to do a tune, i have a 00 z24 with the gm supercharger and stock pulley. i think i might get a smaller pulley before i get it done, but will pay and drive to you. Want somebody that has done several with good results please! thanks
Your location would help.
huntingdon from his profile.
I haven't done an LD9 s/c before, but if you're basically stock it won't be hard as long as you have a wideband.
Your reg isn't filled out so sorry if you already have this stuff, but if you're going with a smaller pulley, larger injectors are also a must. A full exhaust would be recommended if you pulley down as well.
let me know if you want it tuned. an LD9 using the reflash is child's play.
yes im from central pa, Huntingdon, its just south of State College (penn state), as of right now, it has the supercharger with the reflash Basiclly stock. have run it this way the past 2 years, i wanna do a few things to get a little more power out of it. *better tune* unless it would be pointless if i already had the reflash. any opinions?? no i do not have wideband, and it does have a catback, its nothing crazy. thanks for any help or opinions
The Gm program with a reflash is very easy to tune, do you have a wideband installed, if so i can prob have you up and running in a hour or two
