ok well i think the 2.0 in my sunbird is skrewed its verry high kms and pouring out oil like crazy so im wondering how hard would it be to swap the 3.1 out of a newer sunbird into this car?
get a donor car. strip the engine bay harness and the dash harness out as well as the motor/trans.....    and get the cluster as well, this hsould get you well on the way w a swap
watch for flying sparks!!!
yeah pretty much everything drivetrain and wiring related in the front end. And if  your bird is older than 92 you need the 3.1 fuel pump as well cause its i higher pressure for MPFI.
i know they made a list, but im just making on from what i can think of lol.. they already said most i think...
-engine
-trans.
-main harness (under hood)
- dash harness
- throttle cable
- fuel pump
- ECM
 im not 100% on the throttle cable, but im pretty sure... i think that should be all youll need...?
"Hondas are like tampons, every pussy has one!!!"
