If someone want to stroke a 2.0L OHC engine you just have to find a Daewoo Legenza the engine is a 2.2l with the same bore then the 2.0l...
The only thing i'm not sure is the deck height, but i'm almost certain that is the same height ...
If this info can help someone...
Just to let you know!
If someone want to put this engine in a bird with a 8 valves OHC , you need to keep the water pump, and all the gears and pulleys for the timing belt...  (not the same number of teeth on gears
Deck height and rods are different than 2.0.  2.2 block has stronger mains and bottom end.  Better to use the complete 2.2 engine.
-->Slow
