Hey i just got my ART kit stuck on my cavy, but its really bouncy!  What do you guys have your dampening settings at?  What psi you ride with? thanks
I don't have air, but if I remember correctly most ride at about half or more dampening, and around 50 psi... That's completely from memory though.
the air ride tech struts have 9 different settings on them the way the car rides is the way you adjust the settings on the strut
  i drive at 45 psi     which give about a 2 inch drop
can i haz bondo
What do you set your front and rear dampening at?
this is something that is total preference.  not everyones air ride is the same way.  some people like a little softer ride and some like it the opposite.  its totally up to you.  just set it to the ride height you want and set the damping in the middle.  go drive and see how it feels and then adjust accordingly
he is right i like mine at a stiffer ride
can i haz bondo
man it lifts the car up alot, i have so much clearance at like even 100 psi
i dont have art but i can imagine the psi would be pretty much typical for any bag system but 100psi is alot.  what do you normally ride at?
Well so far i've just been mobbin around at like 50 psi.  But it max's at 150, never even got it close to that, cause like i said 100 is like way off the ground dude.  Pretty sweet really!
my max is 150 too w/ the easystreet bags but anything past about 80-90 doesnt make a height difference.
Really? I'm not even sure, i havent ever took it higher than 100, its bouncy as a mofo, i'm still @!#$in with my settings, hopefully i'll find a nice medium lol
