Thinking abou t lowering my 04 cav with a spring kit will i need to replace the stock struts if i only go about 1.5 on my drop
READ THE FAQ!
And yes, you will. The struts you'll need are all in the FAQ.
yes you will need to buy different struts.  if your only going with a 1.5 inch drop agx's will work fine but any lower than that you would have to go with d-specs or konis
