ok i just got back from advance auto to pick up front strut mounts for a 2000+ cavi for my brothers 98 cavalier to put on his tein basics
well opened them up when i got home and theres only two pieces in the box? a piece that appears to be a spring isolator and then the top blate but i dont see any bearings or anything? just curios if these are right.
the brand is monroe; strut mate mounting kit. part# 904919
also i installed the rear on stock shock mounts and the one side sits half a inch lower then other side with them set all the way down anyone have any ideas on them?
Who needs a sig?
www.sinisterimages.com
Sounds right. 2000+ doesn't have a separate bearing, it's all in one.
That's the reason we genearlly prefer the 95-99 style, where you can replace the $20 bearing if needed without replacing the whole $100 mount (or whatever it costs, I"m just making up numbers).
yea i need to switch to 95-99
I may run 18s, but I can do your taxes in 10 seconds flat.
On my TEIN Super Streets I have to drop on of the rears a 1/4" more to get it to sit level. Half inch seems like there could be an installation error. Make sure you didn't measure the diff with the parking brake on or crooked sway bar.
should of bought the 95-99, their so much better
you cant use the 99 mounts with the tein basic setup or i would of used the stock ones that are there!
Who needs a sig?
ok well i got everything done and everything back together but now need some suggestions please.
this is the front wheel gap with 18" rims and coils set all the way down.
this is the rear same way.
what i need suggestions opinions on is to either raise it or not or just roll the fenders took it around the block turned the wheel and already scraped the one wheel up pretty good and cant have that any more!
Who needs a sig?
pics dont work chris
They work for me. Both in email replies and here.
so do they work or no because there working for me?
Who needs a sig?
Yup, I can see them.
The drop looks really good.
You need to clean the area where the side moulding was.
I really like those rims. They look great with the drop!
