I've never heard of anything stating the coupe and sedan strut mounts are different, but I have a Vibrant rear bar that isn't fitting, and I just tried a GM bar on the front of another sedan with no luck, it isn't even close...it's almost like the strut mounting holes are rotated a few degrees...any ideas?
fortune cookie say:
hmm weird I have the gm strut bar on my sedan and it works just fine. Maybe an accident on your car :X
hees talking the rear bar. and as far as i know and have heard there all the same.
I've had the ractive stb on both the 02 sedan and 04 coupe.
I've got the GM front and Vibrant rear on mine, no problems. If you have any questions call me Monday between 5-10pm (Eastern
), I might be able to help.
Edited 1 time(s). Last edited Sunday, November 05, 2006 7:10 PM
ive had the gm on both my sedans , no problems
and rk sports , and freedom designs rears , and no problems
Strut towers are the same 95-05 Sedans and Coupes. If yours is different it's been damaged/modified/screwed-with.
I have the vibrant bars front and rear on my sedan. The rear was alittle tricky to install. It had a hard time fitting over the bolts.
It did look like the struts would not line up at first, but it did fit.
I installed the left first, but left the nuts loose. Then I was able to push it over the right strut bolts, and tighten the right side, then the left.
LoL maybe turn it around... I have a coupes GM bar on my Sedan.
