How are the brakes connected to the power steering? - Suspension and Brake Forum
Sunday, November 04, 2007 8:00 AM
The other day I did a quick left turn while doing some modest braking. After that, my steering was whining and grinding like a mofo when turning the wheel. This even happened when the car was stopped and you moved the wheel. It goes away after some time after having the car off. Anybody know what kind of connection is there between the power steering and the braking of the car?
Re: How are the brakes connected to the power steering?
Sunday, November 04, 2007 3:18 PM
Obvious help... check power steering fluid. See where whinning noise is coming from.
Sunday, November 04, 2007 3:33 PM
They are not connected, just a coincidence.
Sunday, November 04, 2007 3:56 PM
its NOT a coincidence, its happened to me many times under the same situation.
Fluid level is something that did occur to me earlier, im gonna have to check on that.
Sunday, November 04, 2007 7:12 PM
only tie between the 2 are the engine , when the PS puts a load on the motor , the vacuum changes
the power booster works off vacuum , if your getting a constant difference , check the check valve at the booster and see if the booster is holding vacuum , engine off pop the check valve outta the booster , if you hear a air rushing sound , its working , if you hear nothing than its bad , or the booster is bad
