I have had a couple people having problems fitting up my tie bar with their custom exhaust. Is there interest if we can build an aluminum bar that will go under or around the rear exhaust?
Mark-oem
http://www.overkillengineeringmotorsports.com/
if putting it down on the absolute lowest point possible at the bottom of the axle arms doesnt work i dont see how you could make it any more clearance friendly.
PFFT secret cams?! pm me if you want a real upgrade.
hmmm... i guess my imagination failed.
Mark, make a few CAD drawings, or something and show the people what you mean.
z yaaaa wrote:hmmm... i guess my imagination failed.
I'm with you I do not see how these 2 things can get in the way of each other.
well... as like the tie bar i currently have, it runs off a custom L bracket thats exactly like an addco lower strut bolt bracket, just is longer on one side with an extra hole in it for the tie bar. basically.. it runs from lower strut bolt to lower strut bolt. mine smacks my 2.25" exhaust on every large bump and is extremely annoying. i even used some spacers to move it down a 1/2" further and it still hit.
so, i wanted a different one. one that bolts to the bottoms of the axel arms. its actually about 2-3" lower than mine. needs to be a ton longer but its out of the exhaust's way. and thats all i cared about.
