hey everyone i was wondering what master brake cyl would i use if i were to delete the abs on my 95 cavi
wanting to know asap as i have to get my car back on the road soon
Thanks
Matt
could you not just remove the fuse?
i need a new mastercyl cuz mine is effed up
get ahold of stroker scott
Every time I scream "Release", I mean it, you know it. I feel the day. Black 7.
just cut the abs wires runing to your control arms and youl have no more abs but the abs light on the gauge pod will stay on
if it start the next day it can be driven harder
reading owned people in this thread. . .
Matt, get a Non-ABS master from a 03+ Cav/fire. only thing, the lines are different, so be careful on that part.
Matt, I have an abs master that will work on your car.
I was wondering if you still have the master cylinder for sale.
i thought we posted a how to a while back on deleting abs ?? the 03+ is the complicated way, since it still has a distribution block...easy way is to use older N or L body master with the built in proportioning system...youll have to put new fittings on the line but it sure saves ALOT of space in your bay. and like everyone else said...youll have the Ebrake and abs light on on your dash...so youll have to block those out or pull the bulbs...might wanna try a
SEARCH ... theres several threads on it
look at how old this thread is. . . .
