Has anyone successfully got big brakes under stock z wheels? If so what rotor diameter were they?
mainly curious about 13inch setups.
-Z Yaaaa- wrote:yep i just got sent a picture message with that exact setup.
13" brakes behind 16" Z rims? How big were the spacers needed to do this? I'm curious, because 12" brakes are hard enough to get behind those rims.
Was the OP reffering to a actual big brake kit? Like a wilwood kit?
Just curious about what people have been able to stuff behind a stock wheel, kit or pieced together.
Brad, what setup is that?
Jay Van got stock Z wheels over willwoods with spacers.
lol i dont honestly know. the person that owns the setup should really answer that.
Come join us over on the Olds Quad 4 and Twin Cam Facebook group!
Brad, that still doesn't address the question, LOL. How thick were the spacers needed to do this?
Slowzee wrote:I didn't use spacers
Is that your setup with the F-body calipers? I'd really like to see it without the wheel, front and side views. I know for a fact that the caliper sticks forward over 10mm farther than the J-body one does, and others have said they tried to get those behind factory 16's and they hit the spokes.
First off, Brad blows.
Second, here is the details
W body 13in rotors, w body STEEL 2 piston calipers which have smaller piston bores than fbody and are considerably shorter in height, allowing fitment under stock 16s, im quite certain that I could get a 15in wheel over these.
No spacers need to get 16s over these brakes, just slide the wheel on, I will be installing tomorrow so I will try and get good photos.
Edited 1 time(s). Last edited Friday, March 09, 2012 4:24 PM
Slowzee wrote:Second, here is the details
W body 13in rotors, w body STEEL 2 piston calipers.
Interesting setup, but I don't know why you'd want to have all that unsprung weight on if you're going for performance.
You mentioned that the pistons are smaller, giving more clearance on the outside, but what about the front clearance to the spokes? Are the calipers narrower as well?
They are narrower since its steel and not aluminum, and I don't care about weight, car will forever remain slow and a daily
I can definitely feel a difference in the unsprung weight in my setup. The car doesn't seem sluggish or have handling problems but the suspension is noticeably more bouncy. Can't get the teins adjusted right. Its not terrible, just the suspension felt perfect before and after it is a little off no matter what I do.
Slowzee wrote:...and I don't care about weight, car will forever remain slow and a daily
It's not always just about being fast. Your car drives differently with more unsprung weight. It's less predictable. I'm just curious why someone would be looking at installing big brakes, clearly a performance-oriented part, and not paying attention to the amount of unsprung weight they're adding.
Is there an adapter on your wbody setup? I can't tell.
Edited 1 time(s). Last edited Saturday, March 10, 2012 2:53 PM
