wel i finally put my kit in and it was farly simple.. sfter about hitting the switch 15-19 times my back left bag poped, then i went to put my other side up so it wouldnt rub, and then the other bag poped....is is a defect problem? i hope so cuz i just got off the phone with aim industries, and they said if its a defect no charge... damn im angry!!!!!!
were u putting too much air in the bag?  i know for my kit, easystreet recommends that you dont fill past 150psi.  even at 90 psi its at its full height.  also was it rubbing on the inside of your fender?
wel i just took the back struts out, bot in the same spot have holes in them.. the tire is rubing on  them when the bag is filled half way.. all the way down and up  its fine, but in the middle is tends to buldge out and rub against my tire. ...aim industries wants $189 for new bags and it just going to do the same thing everytime... or $650 for cylinders what should i do. ???????????????
thats weird.  are they actual bags or are they sleeves?  i have sleeves in the rear so there not as wide as the bags i have up front
theres sleeves , there difernt than the front,  i think it sticks out from the weight when the bags are filled a little bit........ any ideas what i should do?????????? i should have just went with easy street!!!!!!!!!
well you should of searched before you got aim.  i could of told you right off the start aim sucks.  only people i trust are easystreet and air ride tech.  its up to you.  for the price of the cylinders they are charging you, i would buy easystreet rear sleeves and use those.  it would probably be cheaper and this way you wont have to buy accumaltors for the cylinders
