Someone told me to weld the highest bolt on the bottom of my easystreet stuts to keep them from slipping and messing up the camber. Did all of you with easystreets do this? If not, what did you do to solve this problem?
what camber problem?  i never had a problem.  go get it aligned
bigj, try it without welding first.  just make sure you tighten them very good because i think mine were coming loose because my tires were rubbing, thats why they welded them.
Well, I would hate to have to get it aligned twice. I was wondering if anyone else had this problem. I guess I'll just ask the shop I go to.
i never had a problem.  the only problem i have is the noise when you go over a bump from the strut mounts
Yeah, they make more noise than I thought they would. The noise that bothers me the most is the loud "pop" when I air up the front, but I guess it's normal. There has to be a way to fix the noises!
the pop is the bag itself.  it folds into itself when you let the air out and creates like a suction on the bag.  when you raise it, the seal break and you get the pop noise
were your stock ones welded in? then why should these be any different
i havent had any problems with mine
Phil Thacker
JCO North President
