i have a squeaky sound coming from my front right strut and dont know why my car is an 04 and only has 27k on it and i dont think it should already be squeaking its not the sport model but has the sport suspension and the sport wheels so how can i get rid of the squeak or do i need a whole new strut
When does it squeek? Bumps, when braking, normal driving?
it pretty much squeaks all the time but when i hit a bump or break it gets louder
does it just need grease?
If it's a constant squeak noise, it may be your brake pads (need new ones).
If it's a back and forth sound, it may be the struts wearing out extremely prematurely.
Isn't you car still under warranty? If so, let Mr. Goodwrench figure it out.
Instead of starting a new topic I figured I'd just use an old one. I have a squeaking coming from my front right suspension area as well. Happens basically over any speedbumps, or dips in the road large enough to make the body raise/lower. '03 sunfire so I do still have warranty, I'm curious what it might be though. Any suggestions?
i got a noise from the back passengers rear side dont kno what it is im thinkin its the mount but unsure?
Ty W wrote:Instead of starting a new topic I figured I'd just use an old one. I have a squeaking coming from my front right suspension area as well. Happens basically over any speedbumps, or dips in the road large enough to make the body raise/lower. '03 sunfire so I do still have warranty, I'm curious what it might be though. Any suggestions?
Check your swaybar bushings.
Thank you, now just to look up checking that
