Alright.  Got my air ride installed all of the way.  Now when i turn the wheel they make a horrible creaking and occasionally a fat pop.  Ugh what's the matter?
I have the air ride technologies kit.  It seems like the bag is turning with the wheel...
do the bags sit on the strut mount correctly?  The strut mount has bearings in it.
oh does it?  @!#$ um.  Do you think they can fix it when i take it to get aligned?
Richard Stanley wrote:oh does it?  @!#$ um.  Do you think they can fix it when i take it to get aligned?
Sounds like something you should check/fix before you take it to get an alignment.
www.TaillightTinting.com   #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com   BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
Well that would be nice lol.  Its like a block down the street.  I have no clue whats going on, it's assembled like its supposed to.  No difference between the right and left struts right?
So just so i'm clear, the bag is not supposed to turn with the strut?  It's supposed to remain stationary?  Because it seems like thats not how its designed... hmm i dunno whats the deal?
the bag is part of the strut.  the struts turn when you move the wheel, hence the bag will turn as much as the strut does but it should be secured on the strut itself without moving.  if that makes any sense
there should be no noise from the struts,  somethin went wrong  i have never heard of a struts go bad from air ride tech  i would call them and tell them what is goin on
can i haz bondo
I took it off to see what i could see.  The top bearing is definetly bad.  So can i pick up a set of these from GM and just slap them on?  How does the button on the top come off?  (damper adjustment)
DO NOT TAKE THE STRUT APART!!!
    just go buy the mounting plate  that should solve the problem     go to pep boys or auto zone will be cheaper
can i haz bondo
I will go do that.  I'm not to clear though, whats a mounting plate?
go to store:
Ask for
UPPER FRONT STURT mounts.  it should have Spring seat and bearings.
