Simple question... where is it?
my manual doesn't give good pictures, actually it's mostly black with an arrow pointing to a screw to drain... not helpful, so where on the engine is it located?(there's 1 on the rad, a bunch of bleeders, and apparently a block drain plug?)
Thanks
Scott
Its under the right core plug if you are facing the engine. There are 2 on the front of the block, just look under the one on the right side.
mines green not sure if they all are, twist and pull!
Orangecavy wrote:mines green not sure if they all are, twist and pull!
The one on the block is a metal bolt that its the same color as the block. your refering to the one on the radiator.
