Can anyone give me some advice on some easy performance options for the 2200 engine from a 2002 sunfire? Don't have a lot of money yet to get a lot of expensive stuff. Any help would be appreciated.
best thing is leave it as is, and then save till you can afford to do things right the first time, cheap stuff can cost more in the long run when you end up taking it out for the part you relly wanted in the first place
But is there anything besides air intakes and exhaust thats a cheap power adder for that engine?
nope
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
Ebay chip and stickers
JK
Do a search for 2200 performance, lots of previous posts on stuff that you can do to get power (but its not all cheap)
maybe the cheapest bang for the buck, would be rip it out and put in the 3400 v6,
thats what i plan to do
yep thats what I did, I have a 53k 2200 paper weight on the floor in my garage now.
V-6 in the car, thats the cheapest bang for the buck if you can do some of the work yourself.
01 cav w/01 3400 gam gt 4t45e
i know this is off topic but would one of you be willing to sell your 2200 to me? The whole thing as you ripped it out. manifolds, coilpaks, everything. pm me if your interested. thanx
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
some one just asked me about mine, its for sale. Your not going to find a good harness, they have to be hacked to bits in order to do the swap. My trans is missing the side cover cause i used it in the swap, 2001 , 50 something K miles, cnnt remember exact miles. all of the accessories on the engine, trans is still bolted up, no down pipe but the manifold is there.
but you gotta come to ohio to fetch it.
well what i want to start doing is a 2200 build. I currently have a 2200 cavalier 2002, and i want to be able to drive the car as im building the motor, and then swap them out over the weekend. so the harness isnt important and neither is the trans. is it an auto trans or maual. also how much are you looking for it? thanx
Is it hard to swap in a 3.4L wut all is needed for that modification? im assumin da wiring and computer....
Yea i agree with everyone 2200 is not a cheap car to make fast its just not designed to be fast. i started stock and ran 17.89 in the 1/4
put a header and full exhaust and an intake, prothane tranny and motor mounts, 195-60-14's and im running 15.9 at 84 mph i spent about 200 bucks for all my mods. ohh and an exedy stage 1 clutch kit. which doesnt make it faster just better clutch grip.
Easy and cheap.........get a spare head and learn how to port and polish...otherwise your going to spend some money....my 01 ran 17.2 stock when i got it on a 90 degree day....I have yet to go back to the track to see what it can do now......Do some searching there are some things you can do on the cheap but little power will be gained from them. like rocker swaps and the throttle body off a 2.3 quad.
i just became the proud owner of a 96 sunfire 2.2l. 5 speed.first thing i'm a going to do is turbo it.e-bay has a kit for $1014.00 thats supposed to take the 2.2l to 350-375 horses.no motor modifications.bolts rite on.they do say you have to customize your own down pipe and do some cutting of the intercooler pipes.all in all supposed to only take 12 hours to install.hmmmmmmm!
DESCRIPTION: 95 96 97 98 99 00 01 02 cavalier /sunfire 2.2l t3 custm turbo charger kit!!!
Including following items:
turbo manifold 2.2L (cast manifold)T3 TURBO SPEC:
45 trim
2.36 inlet diameter
2" outlet
1/8 npt oil inlet
t3 flange
.42 ar compressor
.48 ar tubrine
wet float bearing
TURBO IS GOOD FOR 25PSI, AND 350-375HP
( THIS MANIFOLD WILL ALLOW YOU TO KEEP THE AC )
-note customer is require to custom make the down pipe and cut intercooler piping
-7lbs psi waste gate ( ajdustable)
-godspeed TYPE-L ( 20X9X2.75" CORE ))
-t3 stage 3 turbo
-oil line & oil return line with fittings
-blow off valve
-universal 2.5" intercooler piping with silicone and t clamps
T3 TURBO SPEC:
45 trim
2.36 inlet diameter
2" outlet
1/8 npt oil inlet
t3 flange
.42 ar compressor
.48 ar tubrine
wet float bearing
-note customer is required to custom make the down pipe and cut intercooler piping
I hope to god you enjoy picking up little pieces when your motor blows up.
mitchell martinez- You got alot of reaserch to do there buddy...
..no way a stock rotating assembly could take the 350-375 power claim without bending rods and shattering ringlands. What would you do about fueling issues, you would have to do the side feed conversion, and get a new pump. That is just the tip of the iceburg as well....
Take some time away from ebay, most of the stuff is garbage take the time to read up, and remember you normally get what you pay for....I hope that was a joke toward the op.
