ok so i was driving down the road and my battery light came on and my abs and the parking break light so i came home shut the car off and tried to start it but nothing and then i jump it runs for a little i try my turn signals nothing and the hit my wipers and the car shuts off...i rejumped it and then used turn signals they work hit the wipers agaijn the car shuts off ...any help is mch appreciated thank you
check your battery ground to the frame and see if its corroded and test your alt.
remove and clean the ground under the battery tray, and check the battery terminals are tight and not corroded.  If you have a delco battery look to see if the terminals are leaking acid, which ends up on the ground on and under the battery tray.
01 cav w/01 3400 gam gt 4t45e
i had just got a new battery maybe 4-5 months ago its not corroded and the battery ground is clean and tight im getting the alternator checked today thanks guys
