What size LED's from
http://www.superbrightleds.com/ will fit in a 00+ cluster? Please just answer the question don't avert from it. I just need to know what size bulb. It is the 6 bulbs used to light the cluster not the dummy lights.
- T.
Full Urethane Wings West Big Mouth Kit For Sale!
YEAH IM AWARE OF THAT. I NEED TO KNOW WHAT SIZE
LED I CAN REPLACE THE OEM BULBS WITH .........
Hence why I asked "
what size leds will fit in a 00+ cluster? Please just answer the question don't avert from it"
- T.
Also correct me if I'm wrong, but those look like bulbs
OEM were bulbs not leds. YES they are soldered in but they're def not led's or the dimmer wouldn't function properly.
Blindz24 wrote:Also correct me if I'm wrong, but those look like bulbs
they LOOK like the tops of #74s.
actually, dimmer functions just fine on my leds. AND cathodes.
^ Lucky, was told otherwise recently due to LED's drawing a different current I believe ? It was during a discussion on alternatives to led placement without having to separate the circuit board and the cluster face by just adding led's between the 2 pieces which would make the dimmer useless as those leds wouldn't have been hooked up to the factory dimmer/location.
5mm seems maybe too big, I thought maybe 3mm ?
- T.
the dimmer works on mine to..got the 3 pack of leds from autozone
^ do you have an 00+ cluster ? What size LED's did you go with ?
- T.
i actually just cut the wire that goes to the cluster and mounted my own lights behind it...im sure i could have done it the right way lol ...but my impatientness got to me once again...but i belive you can go to sylvania website and look on there, maybe they have them
I dont want replacement bulbs ... the title of this thread says led not bulbs ... So I need to know what size LED's will fit where the bulbs are! lol
- T.
