i have had 3 cavi and for some reason i have had the same  noise that comes from the front right corner
when i take off hard and i brake hard i have all new bushings in the front end(motor mount tranny mount new)new spings(1.7 drop)
the only thing i have not touched is the sway bar bushings?
i dont think i am going to be the only one that has had this problem(noise) because 2 out of 3 have had the same noise.
i think this might be a common noise on 96 and up to 99 z24`s
What kind of noise? Banging, grinding, clunking, chirping, rattling, whirring? If you want help youre going to need to be more specific. Specifically which bushings did you replace? Did you replace strut mounts when you did springs?
