Hey j-body, i just want to be 100% SURE that the speakers i am buying will fit no problem (i recently bought a pair that DIDNT and i dont want that to happen again)
- So please only respond if you have experience with the speakers or know 100% sure they will fit, thanks
- My car is a 1998 Cavalier Sedan (if that makes any difference fitment wise)
-THESE ARE THE SPEAKERS IN QUESTION (WILL THEY FIT?)
Infinity Reference 6000cs
OR
Infinity Reference 6010cs
- PS, THESE ARE THE SPEAKERS I HAD THAT DIDNT FIT
Infinity Kappa 62.5i
Fit where?
The doors, the only problem you may have is the depth issue, magnet into the window.
take a look at the this
Sticky!!!!
<img src=http://www.mclonedogmcwad.com/sig3.jpg>
Please visit <a href="http://www.mclonedogmcwad.com">mclonedogmcwad.com</a> and <a href="http://www.realmofexcursion.com/main.html">RealmofExcursion</a>
thanks mclonedogmcwad,
The speakers are for the doors, and i already looked at the sticky, i was just wanted to get info from someone who has installed those exact speakers (either of the 2 i posted).
Thanks, Graham
I have the first one's you pictured, in the doors with a 1/2" MDF adapter.. Also have a matching comp set for my kick panel pods... Also listed in my profile..
You'll be fine bro..
"If life throws you a curve, pop the clutch and drift it!"
Star Quester, you have 2 sets of componets in your front?
Wow, nice!!!! thanks for the help
Anyone else got these speakers?
I have the 6002i they fit good with 3/4" mdf plates
09 HHR LS, Wife's Car
05 Cavalier, Clarion DXZ375MP, Autotek MM8000.5 & 13Kv.2, wife's old car, updates coming soon
what is the deapth on the speaker that didnt fit, versus the componet set. that should answer your question..
It wasnt really the depth of the spearker, rather the platic that surrounds cone to the magnet, that was stopping it from going in the stock hole. I could have cut the metal of the door to make it fit. But i would rather find a set that didnt require much fabrication (besides building the MDF speaker adapter).
Thanks
okay i'll buy that, most peopels issues are usually the deapth. usually with that type of install it can be adjusted with the trim ring. the further away from the door u mount the speaker the smaller an opening youlle need. so allot of time you can adjust the mounting points slightly to get what ya need.
dont forget to seal the wood to the door and seal up all the holes in the door. that should help your sound out allot.
Thanks Jason
So inconclusion, will the Infinity Reference 6000cs or Infinity Reference 6010cs fit with out any problem?
cheers
6000cs will for sure, check the specs on the new ones - I haven't seen those IRL yet.
