Well got cut off today on the interstate and went to hit the horn on a women and all i got was silence horn doesnt work.
I checked the fuse and it looks good and i was wondering what could cause this?
Could be the wire or the relay. Check to make sure the positive wire is plugged in, and try a new relay.
Beat it like it owes you money
get one of those licence plates that say
"HORN NOT WORKING"
"WATCH FOR FINGER"
Yeah. relay or actually horn itself gone...hook a wire from the pos. battery terminal and touch the pos terminal on the horn to check it.
ok and where can i find the wire for the horn at?
I actually had to relpace the horn the other day on my cav. the terminals were all rusty and it didnt work I even tried cleaning it. I could hear the relay clicking so I knew it was good so i tested the harness cause my friends 03 Cav had to have the harness replaced. But yea my issue was my horn crapped out.
Horn is going to be up front somewhere, i'm not 100% sure but i want to say passenger side? Try searching, i think there was a post about a horn before.
you may start by checking the fuse my horn is currently out / i use my bov to hiss at people
slide or die
i did check the fuse and it was fine
