just bought an eclipse cd8445 deck and am trying to get it all set up sound wise...im having a problem with the cross over i cant remember if i should set the crossover at 60hz or 200hz....i have a sub and all aftermarket audio....
I AM the man from Nantucket
If those are the only two choices I'd say 60hz, if it gives you options inbetween you'd could start at 100hz which is a little on the high side and work your way down til you find a setting that works best. Depending on the setup somewhere between 50hz-80hz is the norm.
yea there is like 5 or 6 different settings
