as the title says which is better of the 2 amps? I have the Viper right now but am looking at this hifonics amplifier.
Hifonics specs
Sonic Electronix
Product Description:
1500 Watt Class-D Monoblock Amplifier
RMS Power Ratings:
500 watts x 1 chan. @ 4 ohms
1000 watts x 1 chan. @ 2 ohms
1500 watts x 1 chan. @ 1 ohm
Wired Bass Remote Included
MOSFET Outputs
Complementary High-Speed MOSFET Output Devices
MOSFET EXVP (Exponential Vari-Power Supply)
SPC Twin Turbo Torroids with Simpatico Coil Design
21st Anniversary Edition Heat-Sink Design
Silver RCA Connectors
Balanced Line Input with Optional Balanced Line Driver
Fully Adjustable Accu-Cross Crossover:
Low-Pass Filter (35 - 250 Hz)
Subsonic Filter: (15 - 35 Hz, 24 dB/Oct)
Phase Adjustment: 0° - 180°
0 - 18 dB Bass Boost @ 45 Hz
Adjustable Input Gain Level: 0.2V - 9V
Power and Protection LEDs
RCA Outputs: 1 Pair
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 500 watts x 1 chan.
RMS Power (2 ohms) 1000 watts x 1 chan.
RMS Power (1 ohm) 1500 watts x 1 chan.
Bridged RMS Power Not Bridgeable
Peak Power Output 3000 watts approx.
Min. Impedance Unbridged 1 ohm
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 0.08%
Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover LP (35 - 250 Hz), Subsonic (15 - 35 Hz)
High-Pass Crossover N/A
Low-Pass Crossover N/A
Subsonic Filter N/A
Signal-to-Noise Ratio 96 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote N/A
Fan Cooled N/A
Fuse Rating 60A x 2
Warranty 1-year SE
Viper
Dynamic Power Rating: 1500 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 450 x 1
Rated Power @ 2 ohm: 800 x 1
Rated Power @ 1 ohm: 1200 x 1
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
__________________
I would honestly take the Viper over the Hifonics any day.
viper= usually underrated.
Hifonics= usually slightly overrated.
Elemental Designs
Performance.Mobile.Audio.
alexl@edesignaudio.com
Warehouse Manager
good to know. My choice has been made.
the hifonics XX line is underrated but everything else is a little overrated. ill go with the viper i had a viper 2500 and 2 dei 1500D's and loved them.
I wanna get a bigger amp at some point. I wanna find a older Orion 2500D or 5000D
DEI will always be head and shoulders above Hifonics in my book.
I just bought a 20 inch widescreen ultrasharp flat pannel..I'm going to have to subscribe to the high quality porn places now......damn
This will be powering 2 Cerwin Vega VMX-12.4 subs.
Have you considered looking into amps that are strappable.
That way you can get a smaller one now, and then add another to add power later on?
In alot of cases, its more cost effective than one huge amplifier.
Elemental Designs
Warehouse Manager
I have the viper already. I've had the Viper for about a year now.
my hifonics makes the 1500 watts it said too....1542 actually...its a hifonics bx1500d....but maybe my amp is just weird. maybe look at the brutus line, ive always like them better than the titans
Edited 1 time(s). Last edited Monday, January 01, 2007 3:19 PM
the bx 2005D was tested a few times to only put out 1400-1600 watt's rms, the newer bxi2006 it said to put out around 1900 at 14.4 volt's.
the brutus line of amps are good but rated at 14.4 unlike the gen XX amp that are rated at 12.2. in the next few weeks im goin to pick up 2 bxi 2006's or 2 herc's im not sure yet.
just dont let the hifonics amps go below 10v they like to smoke
