Are the bulbs in the Instrument Panel Cluster 74's and 194's ?
Also, does anyone have the pinout for the connector on the back of the IPC. Want to figure out if I can feed the digital or analog Tach signal from my engine directly to the IPC Tach.
Thanks...
Okay. Bulbs are "PC194" and "PC74". Thank God you can buy them with the plastic housing.
Now all I need is the Pinout for the IPC.   Thanks Again...
Forget the Pinout. Brain finally engaged...
