So I upgraded my interior speakers
Alpine Type S 4x6
Alpine Type R 6x9
The 6x9s sounded like ass without an amp so today I decided to do it myself. The amp im using is the
Alpine MRP-F250
250w 4 Channels
To this point im stuck. Ive had subs installed before so I kind of went off what was already wired just took the 4 gauge wiring out and put in new 10 gauge Tsunami.
Plus theirs this converter box that is wired into my one 6x9 (yellow/Brown) wires then theirs rca plugs which I assume goto the amp.
anyways here are some pics .. Hopefully someone could help me out with what goes where and such
What goes to these wires on the amp?
my ground
the rca wires go here somewhere?
Reds the battery,Browns ground, and blue is the remote?
Converter box
Wires from converter box wired into the 6x9
So am I close to getting these running??
Thanks
Stock Deck
Also factory amplified - so theirs 4 wires to each 6x9
if i remember correctly  those extra wires are for the tweeter in the stock speaker.
all you have to do is wire them up as if the are one set of speakers.. meaning positive and neg. both left and right.
to one side.
did you try it already just make sure that you have the Power wire fused up by the battery and make sure that after you wire up the ground  and remote from the remote turn on from the converter box that the fuse is the last thing to be put in and you should be good with what you have.
since your using the rca converter then get rid of your plug that has the 8 wires on it... you will use your left and right rca for the converter left and right..  then you should be opn track!!
GOT ECOTEC?
