Does anyone have the pinouts to the back of a 2007 G5 Radio with XM ? I want to put this radio in my '96 Sunfire.
just try and get a reverse harness for the radio....but most likely it wont fit anyway....
you know that will have to unlocked by the dealer
Definitely will NOT work in a pre-2000 J-body. You don't have the required Body Control Module to turn the thing on... the 2000+ radios don't use a switched lead to turn it on and off anymore.
Aside from it not fitting in the dash...
Also THE XM (if that is why you wanted it) IS NOT BUILT INTO THE RADIO.
The XM module that came in the G5 is most likely mounted in the read of the G5, also you would need the harness than controls the module along with the antenna.
Just buy an aftermarket radio.
