1800-2000 watts. Bigger alt probably? Ill be running two amps strapped so 1/0 run into a D-block? Or two 4 gauge runs? I have enough 4 gauge so Im leaning that way. Second battery? Final question. I can wire the amps seperately and give each its own sub for 1000 per sub or just strap the amps and wire the subs together to 2 ohms as thats as low as the two strapped will go. Im still leaning strapped because gains etc would be easier right because the slave amp just follows the master amp. Id also have to get splitters for the RCAs. Is 200 watts really worth the extra trouble? Help if helpful. Thanks.
200 watts surely isn't worth the trouble.  Once you start going that big, I'd go 1/0.  And an alt.  And a good battery in the trunk if you don't have already.
The amps only accept 4 gauge. Isnt two runs of 4 gauge the same as a run of 1/0 gauge? Or is it the same as 2 runs of 2 gauge? I havent ever really seen 1/0 to know specifically.
Alt wise Im thinking large case probably?
Should I move my Yellow Top to the trunk and put a Red Top in the front for starting? Or leave the Yellow Top and get a Kinetik or something like that?
Ya and the amps are the SAZ-1000D. And the subs are Type-Rs. Im just picking up another of each to match my current setup.
