I have two dvc 2ohm subs and 4, 2 , and 1 ohm stable amp. Will i be able to run these subs so they are wired at 1 ohm to get the most out of my amp?
"No greater love than this that he lay down his life for his friend"....John 15:13
TADAAAA!
2ohm is the best option. 0.5 will probably ruin your amp.
Yes and no.  Technically, you could run one coil off of each sub, and either short, put a resistor, or put a variable resistor across the other coils, but that gets very complicated for proper sound.  Your options are 8 ohm, 2 ohm, and 1/2 ohm with those subs.
Your car may do 13 sec @ 103 mph, but my car does 146db @ 35 hz.
^ I've wondered if that was possible, but never bothered to try or research it... now I know. Thank you
ok two ohm it is..damn lanman i shuda got the opti2000d or the brutusw 2600d..instead of my 1600d brutus, cuz i dont think ill be wanging
