well Ive been researching turbos and just learning as much as i can on different styles
i have a 2002 cavy with the 2200 ohv
im doing a turbo project for the cavalier and im getting a T3/T04E
what is the difference in a 50 trim and 57 trim? pretty much is it just 50 trim will spool faster than the 57 trim?
and how do i size the A/R? do i want .48 or .63, can anyone explain what these numbers mean
i am knew to picking out these options so please cope with my lack of knowledge on turbo specs.
 last but not least, who is the best place to order this specific turbo i want. i don't want to get stuck with a crappy vendor, Ive been looking into turbostore.com and spoolinperformance.com but turbo store only has the 57 trim and spooling has the 50 trim but it costs about 120 dollars more what should i do
thank you
Larry Carlisle
To be real basic, the smaller the number is on the turbines a/r, the faster it will spool. It's up to you which one you want though.
Check out
www.cheapturbo.com
thanks adam
i actually found a site that explained what all the numbers meant and i figured i am going with the T04E 50 trim with .48 a/r and i ordered it from cheapturbo.vom last night for $619 shipped
thanks for the help
good stuff www.turbosbygarrett.com has some good info on turbo sizing too.  small exhaust turbine will increase backpressure and spool quick but die up top, larger a/r (0.63) will decrease backpressure causing (in most causes) slower spool, with more pay off at the top end.
larry carlisle wrote:thanks adam
thanks for the help
You're welcome.
