I'm in the process on installing my lc-1 wideband. And i have a Q
The wires are as follows.
Red got to a 12v switched source
blue is the heater ground
white is the system ground
yellow is analog out 1
brown is analong out 2
green is the analong ground
black is the calibration wire. And is not used with the lc1
My Q is i don't want to datalog with this wideband. I have hptuners to do that with.
So if anyone has this kit installed and are not dataloging with it what did you do with the
yellow, brown, and green wires. It doesnt say in the directions. I would assume they aren't used.
But if they must be hooked up i want to do it all at the same time. don't really want to take my dash apart more than i have to.
I did search but came up empty for the answer to my Q. So if i missed it please point me in that direction.
Thanks for your time.
You need to hook the LC1 into the HPT if you want to datalog FYI so you'll need one output connected.
5K PB: 24:50
10K PB: 54:26
^^^ How would i hook the analog out into hptuners.
If you have the EIO version you just connect the wire to the box. If you don't have the EIO version....your SOL I believe.
5K PB: 24:50
10K PB: 54:26
