hey guys I just want to know if there is something that exist, for preventing overboosting??? 5-6 month ago I overboosted due to a vaccum that goes out blower my engine! so I decide to start searching about that because i want to go in big number but i want to play safe!! if something exist for cutting ignition if boost comming too high because when overboosting could happen you dont have eye every second on your boost gage so it happen so fast you dont have time to react and boom! if someone can help!
http://cavalierdomination.monchar.com
I know my profec-B has an overboost feature, and a warning feature... I'm sure other aftermarket boost conroller products have the same thing.
-Chris-
-Sweetness-
-Turbocharged-
SweetnessGT wrote:I know my profec-B has an overboost feature, and a warning feature... I'm sure other aftermarket boost conroller products have the same thing.
-Chris-
The Profec b won't do anything if the overboost is due to a vacuum line blowing off the wastegate. Last summer my wastegate line popped off and i hit 29.8 psi, holy @!#$ fast lol.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
zipties or something else to clamp them tight
300hp&tq coming soon
Team GREEN
Adjustable BOVs can be used similarly. You can set it so that it opens when pressures get to a certain range...a factory 1g DSM BOV will start releasing around 18psi for instance. It's kind of like overboost protection, just unintentionally.
fortune cookie say:
Ahhh... thanks Jeremy I read that wrong.
As he said... if that line comes off... there's really zero you can do - you have no control. You're up sh*t creek without a paddle.
-Chris-
-Sweetness-
-Turbocharged-
you could also get a pop off valve which will release at a certain amount of pressure no matter what.. i know they use them in a certain race series to keep the playing field even... basically hit 6 psi it opens... get below 6 closes.
6 month ago i hit 22 psi with my ecotec and it blown my engine... so there is nothing except a warning gauge???? some stock turbo car like my friend dodge charger are cutting ignition at 15psi I tough something similar could exist... when a vaccum line break it dont tell it to you so if you are WOT boost is comming up so fast you dont have time to react!
Steven Lemay wrote:6 month ago i hit 22 psi with my ecotec and it blown my engine... so there is nothing except a warning gauge???? some stock turbo car like my friend dodge charger are cutting ignition at 15psi I tough something similar could exist... when a vaccum line break it dont tell it to you so if you are WOT boost is comming up so fast you dont have time to react!
dood stand alone.
You have to understand, the stock ecu was not meant for boost. it isnt going to have booost sensetive features.
the soultion:
standalone, go ms its cheap, its esay, and on your engine,everything you need is right there. Im telling you. go ms its a wish come true for boost feinds.
BTW if you go for it hit me up and Ill tell you everything you need to know
Kick azz is my boost hero!!!
euhm.... i do not really like the idea... i dont want to do something very difficult...I actually use a SDS EIC (piggy back) for fuel tune up.. seriously I would prefer hptuner instead of a mega squirt, but i dont want to spend somme big amount of money again, maybe i will just be alert if anything goes wrong and later ii will change my mind and buy a standalone but for now i dont want to buy that
Shifted wrote:You could use a pressure switch to cut the power to the ignition if you really wanted to...
i have alway thought of doing something like this
Skilz10179 wrote:SweetnessGT wrote:I know my profec-B has an overboost feature, and a warning feature... I'm sure other aftermarket boost conroller products have the same thing.
-Chris-
Exact same thing for me too ...
I over boosted to 25, and god damn did it get there quick ...
I have an idea,
run a waste gate to your charge pipe.
no really think about it. set you wastegate to a certain boost pressure, and if it over boosts, the second wastegate will catch it.
Lol..I was thinking that as i was reading that as well..a good idea as far as im concerned...id do it..id hate to blow my engine caus e avac line fell off..that would be gay..phil
Jcavi wrote:I have an idea,
Bad idea. So many reasons why that i won't even get into it.
