hey what does it change if it goes all the way soft or all the way hard? does it mess with the sound?my greddy has a screw on the top that says hard or soft.
Basically, if you're pushing enough boost pressure to push the valve open causing a boost leak, you tighten down the screw to hold more boost.
_________________________________________
450WHP Turbo Ecotec swap in the works...
if your running stock boost don't touch the screw, once u decide to boost higher turn it towards hard depending on the amount of boost your running
regular setup - 689awhp/793tq @ 50 psi on race fuel
winter setup - 353awhp/401tq @ 25 psi on 93
1992 Mitsubishi Eclipse GSX - current
1991 Eagle Talon Tsi AWD - Sold
On anything under 10 psi you'll probably want to set it as soft as possible.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
or you could have a HKS SSQ
and not have to worry about boost leaks
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
Why would he worry about leaks with the Greddy????
BTW Josh, i'm still waiting for you to show me all the people pushing 250+whp with the M45 that i was wrong about.
