take a look at the timing cover right where the botls go in to hold the cam gears to the cams.. make sure the bolts haven't pushed outward on the timing chain cover at all.
Jay qwickZ24 or something like that had something that sounded similar. Idle there was no tick, rev it up a bit and you could hear a tick, rev it more and the tick went away. I was bad wrist pins
2006 Black Cobalt SS Supercharged G85
13.91@102.77
Im going to look into both of those ideas.. thanks for the help/comments guys
I had a similar noise, but louder. Turned out to be a bad rod bearing.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
The plastic couplers in the snount of most Roots blowers (M45, M62, M90, M112) are all known to ware out over time. That could be your noise, listen close to see if you can find out just where the sound is coming from. A long extension placed all over the supercharger and engine can help you determine where the noise is coming from.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
supercharger only 2 months old..so i hope thats not it, and it sounds like its coming form motor..i put my ear all around it now..and its coming from top of eninge ..going to take it somewere to get them to det what it is then i'll fix it
You might be able to use the dowel rod trick to locate the noise.
I wasn't able to play the vid but i'll share some of my experiences with a ticking noise coming from the engine with the charger:
Water pump went bad and was sending ticking/chain like noise from the timing chain cover so i had the pump replaced and was good to go.
Most recent was was last week, i thought the pump went again (40k later) cuz i had a similar noise. I used a flathead screw dirver to magnify the noise to my ear. Pretty strong from the timing chain cover AGAIN. So i took it in and then the dealership got back to me and showed me it was something else. the bracket that supports the charger has a free spinning pulley and the bearings in THAT was going bad cuz this was the loudest point and it transfered noise to the timing chain cover. So they ordered me a new bracket for the charger cuz they can't find a replacement pulley. Good luck with the search tho.
...... ahhhhhh, to bad no one looks in to old posts,
this hapened to me, looked in to geting that brackit, cost around 200 bucks, so i found a NSK sealed bearing to replace the holething. worked great.
ill pull up that PN for you.
Chris
'02 Z-24 Supercharged
yet again thanx for all the help guys, i am waiting for a check to get here and im goig to drop it off somewere and get them to pin-poin the issue and then ill do the work my self.
NSK Part Number for the Sealed Bearing that replace's the SC IDLER PULLEY
NSK 6403-2RS1/C3
Chris
wondering if you ever found out what the ticking noise was....went to pass someone and i felt something let go.....let it stuck....then a f*%$ing tickin noise...any ideas...and of course it happens on boxing day....
"If you have no clue what's going on... STFU!"
well......turns out i probably have a bent rod..or rod bearing is shot either way....no fire for a week atleast....and i meant "like it stuck" in the post above.
..again talking on a dead thread..so i'm probably just talking to myself..
his was a bad rod bearing, bye bye 2.4
JoeyDaBomb wrote:his was a bad rod bearing, bye bye 2.4
sad, get rid of a better power plant. for something poplular right?
Chris
So it was a knocking rod. I always wondered what it was.
anyone else had problems with the rods or anything....just from supercharging it? It's number 3 atleast that's what i think i've narrowed down to....now i just have to wait to see if it these wrist pins, connecting rod, or a rod bearing.....my noise is alittle different then his inthe video....but doing it at the same time...only during acceleration, and slightly at idle (hard to hear the faint ticking)...won't know till friday when i rip er out....any feedback would be appreciated...this will be my first...
i'm probably redoing the whole motor, since i have to take it out... so parts are somethin i'm looking for if you have any LET ME KNOW! ASAP!
135K. boosted at 30K....
stock motor. water pump too.
Chris
Our cars have problems with the rod bearing stock so it is not a problem only with the supercharger.
THAT was GM useing cheep bearings from 97-99, not 96, 00-02.
Chris
