Anybody had any luck installing this on the stage 2 kit from Hahns? The instructions given to me by the manufacturer basically went out the window....
Josh
SLK 32
Installs just like any other controller exept Im not sure which boost line runs to the IN part of the (( silinoid )) and Out part. The manufacturer instructions work. Check there website. THey might have it on there.
I have the AEM TRU BOOST on my HRC kit, the only trick is setting up the solenoid correctly. The nipples you use on that depends on if it is a INT or EXT gated turbo.
Vacuum cap the open port on the turbo housing, run the WG reference line to the solenoid, and then to a boost reference source. I used my intake manifold so I get an accurate reading there.
FstCavZ24 wrote:I have the AEM TRU BOOST on my HRC kit, the only trick is setting up the solenoid correctly. The nipples you use on that depends on if it is a INT or EXT gated turbo.
It's pretty much the same thing with the Greddy unit ( I run one in my car). You can go to Greddy's website and download the install/owners manual from them.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
Basically run it inline from the WG to IM and you'll be fine. Just make sure to cap the turbo nipple.
I had my MBC that way and it worked flawlessly until I wanted to go higher than it could allow LOL.
5K PB: 24:50
10K PB: 54:26
