Ecotec 16 G turbod at 15 psi. Boost will not stay at 15 or where ever i put it . It will go to set point then it will go down 3-4 psi in 2nd and 3rd gear.4th gear will hold it pretty good. How do i fix this ? tuning doesn't work when boost goes down by it self that far. Please help.
Get a biger turbo.
Internal gate, or external?
Chris
'02 Z-24 Supercharged
check for a leak too
When in doupt, grub.
DSM Turbos dont always hold boost higher than 10-15 psi all the way to redline. Get a bigger turbo if your wanting to run 15+
I've already told you this a couple times, but....
Taetsch Z-24 wrote:Get a bigger turbo.
Its internal. Yeah i would love to get a bigger turbo but money. Does the 20 g turbo loose boost like the 16 g? I know there has to be a good many people out there that run the 20.
You can use a 20g just fine
*Get anything BUT a mitsu turbo
Chris
Taetsch Z-24 wrote:Get a biger turbo.
Chris
I hope your kidding.
Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Borg Warner S200 or 3LM S299. You'll never go back to mitsubishi.
Hell, even Garrett. I'm not a big fan of them, but anything is better then mitsu imo..
Case in point
BlackEco wrote:Taetsch Z-24 wrote:Get a biger turbo.
Chris
Engine:
Mitsubishi TD06-20g Turbo
Hahn Racecraft Manifold & Stage 2 Charge Pipes
Turbo XS BOV
Domestic Concepts 61mm Throttle Body
Custom CAI
Greddy Catchcan
Greddy Profec B Electronic Boost Controller
Threaded 3rd Gen Camaro Airbox IAT
3" Custom Mandrel Bent Downpipe w/ cutout
RKSport 2 1/4" Catback
Magnaflow 2 1/4" Racing Muffler
Spec Stage 3 Clutch
Turbotech Racing Solid Upper Mount
RKSport Lower Mount
Prothane Poly Transmission Mounts
StaticX Grounding Kit
Optima Red Top
Innovate LC-1 Wideband Controller
Tuning ECU w/ HP Tuners VCM Suite
Out of Vehicle :
Port and Polished Head
Si Stainless Steel Valves
Si Bronze Valve Guides
Ferrea springs
Ferrea titanium retainers
Eagle forged 4340 crank
ARP Main Girdle Studs
Eagle H-beam Connecting Rods
ARP 2000 Rod bolts
Wiseco 8.9:1 .020 over Pistons
GM Adjustable Cam Gears
Girdle is tapped for turbo drain back
Oil filter bypass is plugged
Oil sensor location tapped for turbo feed
And whats your best E.T?
Chris
Taetsch Z-24 wrote:Case in point
Chris
Engine:
Turbo XS BOV
Custom CAI
Greddy Catchcan
Spec Stage 3 Clutch
RKSport Lower Mount
Optima Red Top
Out of Vehicle :
Ferrea springs
ARP 2000 Rod bolts
Chris
Hey man...what was my best ET? That's right...it was on a 16G so SHUT IT.
I've gone faster than 99% of the .org EVER will on this so called @!#$ty turbo.
5K PB: 24:50
10K PB: 54:26
And unlike 90%, You think out side the box....
But riddle me this, same boost PSI, but with a GT30R\GT35R how would you have done then?
Chris
Chris
Engine:
Turbo XS BOV
Custom CAI
Greddy Catchcan
Spec Stage 3 Clutch
RKSport Lower Mount
Optima Red Top
Out of Vehicle :
Ferrea springs
ARP 2000 Rod bolts
Chris
105 @ 7psi on 20g
Taetsch Z-24 wrote:And unlike 90%, You think out side the box....
Chris
No offense but who really gives a @!#$ how fast I woulda gone on a different turbo Chris. He didn't ask if a GT30R/GT35R would be a better turbo. He asked for help explaining why he was loosing boost WITH THE TURBO THAT IS ON HIS CAR. Not one that someone else says he needs.
I also don't see how thinking outside the box helped a stock motor, stock clutch, stock axle, minor suspension mod, drag radial car in any way. Now when it comes to Julius V3.0...there's some outside the box thinking at work there.
5K PB: 24:50
10K PB: 54:26
I got one more question. Figured i would put it in here and not start a new thread. How much timing do yall run normally wot? I am just curious. I know that you log the knock and back down untill you dont see any. I already know all that. But i am just curious. Whats most peoples timing for wot being turbod
Hypsy (TRU TurboSport Cav) wrote:Taetsch Z-24 wrote:And unlike 90%, You think out side the box....
Chris
And i answered his question,
same answer as a lot others gave him.
I was just doing a comparison.. Turbo VS turbo. go on the DSM\SRT boards...mitsu turbos love to boost spike and fade down.
Dident mean to ruffle your feathers.
Chris
Taetsch Z-24 wrote:Hypsy (TRU TurboSport Cav) wrote:Taetsch Z-24 wrote:And unlike 90%, You think out side the box....
Chris
I know if only there was some sort of device which could measure this and and make wastegate adjustments according!
Chris
BOOSTED BABY wrote:I got one more question. Figured i would put it in here and not start a new thread. How much timing do yall run normally wot? I am just curious. I know that you log the knock and back down untill you dont see any. I already know all that. But i am just curious. Whats most peoples timing for wot being turbod
It is setup specific, there is no universal number, it could be stock. Determining this is part of tuning.
I have to take exception with negative information regarding Mitsubishi Turbochargers.
We've gone 11.65 @ 118 MPH in our Sunfire with our Super 16G.
20G performances include a raft of 11 and 10 second cars, with a short foray into the 9's with a small shot of nitrous.
Our Super 25G Drag Neon went 9.20's @ 155 with nitrous...on an internal wastegate, no less!
Our TwinTurbo Z06 'Vette (dual Super 20G-N's) makes more torque, along with more HP per pound of boost, than brand-X equipped rivals.
And for the ultimate, we've run deep into the 7's @ 190 with 20G on a series of multi-championship winning Pro Street bikes.
These tubochargers offer efficiency that can rival anything else out there, but at a much lower cost than the hype-driven (and, as time has proven, not all that durable!) ball-bearing GT's. They boast a 12 month, umlimited mileage warranty that is in effect regardless of usage, 5 PSI on the street or 35 PSI on the track.
Overall, an outstanding combination of performance, durability, and affordability. Take it from someone who's used everything out there since the 1970's!
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
What turbo is it that is on your sunfire again?
Chris
Taetsch Z-24 wrote:What turbo is it that is on your sunfire again?
Chris
And that matters why?
Knowledge is gained through experience and trial.
It's a Garret GT40R. There's no Mitsu turbo that big that we could get our hands on readily.
Street-Legal 2003 Sunfire 10.58 @ 139 MPH
Either way the 16g is better than my M45
Now if I could just get a LD9 manifold, LOL!!
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
Chris
Ouch man....that is below the belt as they say. I know Bill would be using a Mitsu if there was a beast big enough to use on that car.
5K PB: 24:50
10K PB: 54:26
