Hi all. I just ran across this site and these blower cams.
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idproduct=2450
It's a little hard finding information on these and just wondering what the install time would be like, and if you think the dealership would have any problem putting them in?
Also i'm thinking about S/C'ing my ecotec aswell. Would the GM reflash work well with these cams? I know the stage 1 requires no tuning but is the blower cam the same?
Thanks to everyone in advance.
I have all the specs for those cams downstairs. Gimme a little bit and I'll post them. I also have a set sitting in my basement that I'll sell you cheap. They've been sitting unopened, except to get cam specs, for about 2 years now. LOL.
5K PB: 24:50
10K PB: 54:26
Directly from the cam cards included in each box....
Intake Cam XE252BHR-13 PN:113251
Valve Adjustment: Hydraulic
Gross Valve Lift: .423
Cam Lobe Lift: .250
Advance Duration @ .006 Valve Lift: 252*
Valve Timing @ .050: 7-*BTD 37*ABD
These specs are for cam installed @ 112.0 Center Line
Duration @ .050: 210*
Springs required. Valve Springs specs furnished with springs.
Exhaust Cam XE252BHR-13 PN:113252
Gross Valve Lift: .436
Cam Lobe Lift: .258
Advance Duration @ .006 Valve Lift: 262*
Valve Timing @ .050: 43* BBD  5-*ATD
These specs are for cam installed @ 114.0* Center Line
Duration @ .050: 218*
5K PB: 24:50
10K PB: 54:26
Thank you very much. But I don't really understand what any of that means
It means they're cams designed specifically for a supercharged engine LOL.
They should run ok on the GM S/C reflash but I don't think anyone has ever tried.
Install time...3-4 hours I'd guess if you take your time. Dont pay a dealer to do it. Get some locals, a case of your beverage of choice, and go to town. Just make sure you torque everything down and you set the timing right and you'll be fine.
5K PB: 24:50
10K PB: 54:26
