1. where are you ohv guys getting the vaccum for the bov's and wastegates, i have to tee off after the throttle obdy right? also what size are the lines for ease of getting the tees and lines, also should i use hard emission line of silicone vaccum hose?
thanks guys!
jason
For the wastegate you want to use a vac line from the compressor outlet, as close to the turbo as possible. Some turbo compressors come with a vacuum fitting on them already. For the BOV, I'm not sure the exact location on your particular engine, but usually on the intake manifold somewhere. It needs to be on the engine side of the butterfly valve in the tb.
" To study and not think is a waste. To think and not study is dangerous. "
