Were is the line for the bypass valve coming off the supercharger supposed to be connected to?If I plug it I make no boost,If I hook it up to a vacuum port I make 3psi and If i leave it unplugged I make around 7psi.Isn't the stock pulley supposed to make 10psi?
stock pulley is around 8, depending on your location. i only made 8-9 with the stock pulley if i remember correctly
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP  333.6 WTQ [10.1 AFR]
the upper hose from the bypass valve goes from there to the supercharger/
the bottom hose you leave unplug, that is for the cobalts as their boost inhibitor line
K. Vega..Mr. M62 L61 himself. wrote:the upper hose from the bypass valve goes from there to the supercharger/
hmm you just gave me an idea.. not sure if it would work or not but.. its an idea
what if you made a pressure switch to hook up to that inhibitor line which you could set for a certain PSI then once it hit it, it switches something to open or close whatever to limit boost? this could be a makeshift boost limit you could use for 1st gear or something
, then hit a toggle switch to disable it once you shift?
just a random idea before bed..
