turbo spits,sputers - Boost Forum
OK GUYS WHEN I START TO HIT BOOST, TURBO SPITS,SPUTERS,ECT.LET OFF GAS IT STARTS TO SPOOL
THAN DOES IT AN. I THINK IT IS A GAS ISSUE. ANY HELP
MOD LIST
2.4 LD9
20 OVER ,TAPER BORE
53MM PISTON 8-1 compression
BALACED,BLUE PRINTED,CRANK SHAFT
CUSTOM MADE TITANUM CONNECTINGRODS
HEAD,1MM OVER SIZED VALVES,
POTED,POLISHED
TURBO, T3/T4 WET BEARING HYBRED
AR50 INTAKE/AR63 EXHAUST
hks bov
whating for in line fuel pump ,440 injectors,fuel regulater,to get here
WHAT'S WITH ALL THE NOISE?????
MAYBE GET YOUR HEAD RIGHT FIRST!!!
"THE STUPIDITY IS STRONG IN THIS ONE"
Gilles
2.3 Ho
hear we go again, nothing but bull sh--
you started farting in the other thread, then you went for a dump on us. Why shouldn't we put your face in what you created?
You asked for it in a way.
Gilles
2.3 Ho
if you could read, all i did was ask a question, than alex replied with a stupid comment ,so i replied back plus you probbaby dont have an answer anyway.but thanks
Just by judging the "Mod" list you wrote, you don't know a bolt to a light bulb.
Will I answer you? No, not worth it.
Will I make your time here a nightmare? probably everytime you act all tough and mighty. It's the internet. If you can't stand it, don't use it.
Gilles
2.3 Ho
I just checked what he wrote and there's nothing wrong with it. He has the right to voice his opinion. Now if you get butt hurt by that, it's not our problem but your's.
Gilles
2.3 Ho
and you are how old ha ha ha
older than you but what does it change in the situation? You obviously don't know what to say so you try to attack me on my age but you failed just like you fail at life.
Gilles
2.3 Ho
and so do i.it is the internet
Action Jackson wrote:and so do i.it is the internet
You approve that you fail at life? Geez, you were easy to convince.
Gilles
2.3 Ho
1. empty registry.
2. mod list hurts my eyes to read.
3. you DONT HAVE TO YELL. makes you look more like an idiot.
4. Dont come in here being a new guy and tell people how to post, wont get you far
5. if you dont like it, click the x in the top right corner and be on your way.
Double post for the loss.
You sir tremendously FAIL!......You F'n FAIL
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
ok guys this is mike. the person you were talking to is my 12 year old son. he is trying to be cool. sorry for his fn mouth.
he just got what he diserved. put block on so it wont happen again.again sorry
1- You birth date is set as November 14th 1984 so 24-12 = 12. Wow, you had a kid at 12 years old?
2 - I'd be rich if I would have got a dollar everytime I heard that excuse.
3 - Do you take use for fools? Don't let my joined date fool you, I'm here since 02 so I've seen my share of people like you.
Gilles
2.3 Ho
that is my wifes bd she is 24 mine is 2-11 1970
she joined me up yesterday that is my sone from a previouce marriag
ITS DEFINITELY THE HKS BOV CAUSING THE ISSUE !!!!! ITS OBVIOUSLY THE MOST RELEVANT AND PERTINENT MOD WHICH NEEDS TO BE LISTED CASE CLOSED PROBLEM SOLVED!!!!!!! NORMALLY IT HELPS IF YOU LIST MORE MODS WHICH AREN'T ACTUALLY ON THE CAR BUT IN THIS CASE IT IS A NO BRAINER!!!!!!
never mind the tune
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Could it be fuel cut? are you running the stock fuel pump still?
Looking past the crap....
Sounds like a two bar sensor with a one bar tune.
Chris
'02 Z-24 Supercharged
thanks. turns out ,never regaped plugs. was having plug blowoff
dam u guys are harsh. seems like a simple question. idk if its the same one i have. when im driving and i shift if i am in high enough rpms or just normal. as i shift i hear a shuttter sound from the turbo? like a tshhhhh idk lol how to explaing it . dont think its my bov i have a hks and i know when i hear my bov. any ideas . i have a t3 t4
