Will 370 injectors with no other mods besides intake and a 64mm throttle body work with the GM flash / program and kit...?
I'm told that the kit comes with 310 injectors and I'm just wondering......what happens if I install the 370's in...?
The guy I bought the kit off of had some extras that I didn't get with the kit so the kit came from him with 370's.(310's are the only thing I didn't get that comes with a new kit)
In the future I will be needing them anyways...( this coming winter adding lightened pulleys, header and such)
help a brother out...!
You can run them, but you will need a tune badly.
Thanks for the reply John...
I know you know allot about this stuff...
More or less it will be sputtering.....run rough...?
What else can I install right off the bat that will work with the 370....?
Truly at idle it will probably run fine. The problem is going to be in PE (Power Enrichment/ WOT) fueling is going to be way off. If you do not have the means to get ti tuned right away then don;t use them. Need some 310's? I have 2 set not being used.
It'll run too rich at all times, but won't necessarily cause driveability issues. Too rich kills your catalytic, and quickly
14.330 @ 96.37mph
