ok i know the cobalt ss supercharged supercharger with fit the 2.2L ecotec. i have been reading a these forms about this (like for hours). all i want to know is what do i need to do to make it work like i know i need a hp tune and a tb plate what else are some thing need to be done and just let u know i paid $800 for the full set up like everything even the altnator and the stage 2 kit for it. help me out guys thanks alot. tony
i need to know details on this like from someone who did it or knows alot about it any info will be help full
i need to know what parts i need everything. thanks alot guys
i looked and looked i sick of lookin i just would like someone to help me thanks
On page 9 Krzy z's list.
- Lower intake manifold #12584348 (same as Cobalt ss)
- Intake manifold gasket # 12597855 (same as Cobalt ss )
- Supercharger assembley # 12584331 ( same as Cobalt ss )
- Supercharger Outlet gasket #12584342 (same as Cobalt ss)
- T/B o-ring #12575463 (a/c delco # 217-1592) same as cobalt ss
-Super charger bolts (x4) #11589214 (Same As Cobalt ss)
- Lower intake manifold brace #12586632 (same as Cobalt SS)
- manifold brace mounting bolts (x2) #11516342 (same as Cobalt SS )
- Intake Manifold Bracket Threw Bolt # 11515770 (same as Cobalt SS )
-Tmap sensor #90423637 (a/c delco # 213-3907) (same as Cobalt ss )
- T-map sensor Bolt # 11588712 (Same cobalt ss )
- Tmap sensor harness # 88988320 ( same as cobalt ss but not y-harness from kit need to be spliced in.
- evap tube #12584369 (Same as Cobalt ss)
- vaccum Hose - fuel regulator # 12584337 (same aS cobalt or just buy bulk vacuum hose)
-Radiator inlet hose #22718761 (same as cobalt ss)
- Fuel injector (x4) # 12593904 ( long style from gm kit fits 03-05 rails) ss injectors are short and may need 02 rail swap.
- Drive belt # 12590815 ( from gm kit, SS drive belt needs 1 rib cut of to fit the stock pulleys)
- Generator Relocation bracket # 12584365 (same as cobalt ss)
-relocation bracket bolts (x2) # 11518051 same as cobalt ss
-Relocation Bracket bolts (x2) # 11589134 ( same as cobalt ss )
- tensioner assmbley # 12583180 ( same as cobalt ss reuse stock tensioner bolt)
-Idler pulley bracket assembley #12584364 (same as cobalt ss )
- Idler pulley bracket bolts (X2) # 11518048 (same as cobalt ss)
-brake booster hose #10358940 (same as cobalt ss)
-Premium fuel decal # 25602518 From gm kit but u probley get the one from the ss but i didnt get that part number.
- Manual Pcm Calibration # 12590820 give this number to the dealer to call in to get the reflash from gm.
-Automatic Pcm calibration # 12590819 Give this number to the dealer to call in to get the reflash from gm.
also tinkle has installed a supercharger from the cobalt ss look him up and he probley can help u out.
thanks alot guy for helping me out. tony
The 2nd post that Cody(RD Fabs) made in this thread is a link to install instructions and a parts list for EVERYTHING that is included in the kit. These are the same exact instructions and parts list that i used.
http://www.j-body.org/forums/read.php?f=40&i=159643&t=159643&p=1
Tinkles
2003 Cavalier 1SV
Bagged and Blown
