Ecotec Saab turbo setup owners....What did it roughly cost you to do the saab setup?
Just under 1200, in the boost forum on j-Bom there is a list of all that's needed and rough pricing. I forget the name of the post.
Member of J-body of Michigan.
Quick question about the saab setup. If you tune with HP do you still need the Cobalt SS T-map? Thanks
no you dont need the t-map. hptuners cannot tune with the t-map. i have a list of almost all the parts you would need including part numbers and prices(i believe) somewhere saved on my computer from when i built my last setup.
gimme gimme gimme! thanks Brandonpauli..
Reflash- 12590819 (Automatic)
12590820 (5 Speed)
Manifold- 12786716(No Air Injection)
12794948(Air Injection)
Turbo- 55562670 (High Pressure)
12788719 (Low Pressure)
Oil Return- 12787669
Oil Return Gasket 90490305
Coolant- 12787770
12787767
Saab Upper Intake Hose 12786816
Oil Return Gasket- 90490305
Block Feed Adapter- 105-2278
Feed Adapter to Line- 361-AT981604
Feed to Turbo- 361-981504
Feed Length- 16 inches
Saab Green top injectors- 12801656
Spark Plugs- NGK 4306306
Threaded IAT(for setups without a TMAP)- Su107 or 2320
Boost Gauge- 4301
Catalytic Converter- 94036
Intercooler Size- 28x5.5x2.5
Charge Pipe Size- 2 Inch
T-Map 90423637 or a/c delco 213-3907
T-Map Harness 88988320
I think thats it, no prices though. thats all i had saved. my setup cost about $1200-1300, but i did a lot of custom stuff and had a lot of things custom made
Thanks again man.. Thats great and you just helped out alot of people.
Do I use all of these if I am going to have someone tune it with HP Tuners?
BP (brandonpauli) wrote:Reflash- 12590819 (Automatic)
12590820 (5 Speed)
Coolant- 12787770
12787767
Boost Gauge- 4301
no reflash, no t-map, no t-map connector. hp tuners will also require a wideband
