Ok I jhad a t28 putting on a t3/t4 does it need a retune with same boost just different cfm should spool about the same
Depending on your current tune, but yes if possible when switching turbos its best to change your tune. I also recommend putting in new plugs as well, Ive had misfires from a fouled plug after changing turbos.
will put new plugs in and hope for the best
Depending on the flow of the new turbo your tune will likely be way off.
well it's pretty much a given that the t3/t4 frame will flow more than the t28.  vote for retune asap
